Home > Puma (Tdci) > Air Conditioning only working LHS vents? |
Very strange, Defender heating system it's very simple, with manual single flap, the air flow is unique for both sides, without separate adjustment between passenger and driver (as for RRS, D4,.... with a lot of motorized valves and flaps)
Anyway the Workshop manual is your best friend..... https://1drv.ms/b/s!AnHBx4Wc2MJLhG6rtxe8woH3N2w8?e=4wdKXL from pag. 819 - ... Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
8th Jun 2019 12:25am |
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 118 |
That is very helpful thank you!! - looking at that I am going to start with a regas given the route the LH and RH ventilation takes,- I will post how I get on
8th Jun 2019 7:25am |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3328 |
Mine did this. The problem wasn't with the aircon rather the heating which needed adjustment as it was running too hot and mixing with the rhs vent when the aircon was on.
Plenty of threads on here showing how to adjust the heating to make it cooler. |
8th Jun 2019 8:04am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
Remember the diagram is for left hand drive. Opposite layout for RHD.
8th Jun 2019 8:43am |
Thanks for all the feedback, thought I would provide an update - had the aircon recharged today, no leaks but coolant was down to 50% so I am guessing it hadnt been done for a few years - now it is 100% and RHS is working -
11th Jun 2019 6:02pm |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Was about to say try a regas, only half the cooler matrix will have been getting cold enough!! Andy
12th Jun 2019 2:48pm |
