![]() | Home > In Car Electronics > LED upgrade with headlamp levelling motor |
RRS2 Member Since: 22 Apr 2018 Location: Southampton Posts: 52 ![]() ![]() |
I have a 2013MY 110, Could someone please tell me if I change the headlights to LED are the levelling motors just a remove from the old and place on the new? TIA
You do not need to touch the levelling motors. Just take the entire halogen lamp units out and install the LED lamps instead. The levelling motors will continue to do their job with the new LED lamps as before.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks Eric
Thanks Brendan, it was the levelling motors I was unsure of, I've had the lights out previously when fitting checker plate to the wing tops
