![]() | Home > Td5 > TD5 - Strange starting problem |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
Over the last few months my 110 has developed a strange starting problem.
This is what's happening; - Turn ignition on - All normal lights come on. Temperature guage normal, fuel pump running - When glow plugs go off, turn to start - nothing, just a click - turn off - repeat the above and it starts If you remove the key from the ignition barrel and try again it won't start but just goes click until the second time of trying. Occasionally it's takes two or more cycles before it tries to start. Things I have tried so far; - replaced both yellow relays under the drivers seat - cleaned up the earch point under the drivers seat - cleaned up te earth on chassis and gearbox My next thought is to check the ignition barrel, but I'm not sure what I'm looking for or if there are other tests I can try. Thank you for reading. |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
sounds like a starter issue and it might need a rebuild to solve it. it will get worse and it will stop starting eventually. The defender has migrated, leaving the owner behind.
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5116 ![]() ![]() ![]() |
Sounds like a dodgy starter motor solenoid. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
Thank you.
I change the solenoid contacts five years ago. Worth having a look to see if they need replacing again. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5848 ![]() ![]() |
Yep. Agree. Starter.
Thank you all for your help.
New start motor solenoid kit ordered from Amazon (https://www.amazon.co.uk/Diesel-Starter-Re...amp;sr=8-4). Depending on when it arrives tomorrow I'll get it installed and update this thread. ![]() |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 828 ![]() ![]() ![]() |
Replace starter solenoid and connections , think you can still buy kit from most suppliers for around £50
https://www.paddockspares.com/red-bison-ho...l-kit.html Have fun be happy |
