oneten110
The latch originally fitted to these doors did not have the facility to lock them from inside the vehicle.
https://www.defendersource.com/forum/f6/do...30594.html
There is an alternative which I have fitted to mine. These offer an internal locking feature but are not compatible with your original trim unless you modify them, by removing the interior handle.
Then you would still need to modify your door trim, because the internal lock is the same as that fitted to the back door.
https://www.johnrichardssurplus.co.uk/cata...?q=Muc1030 It is not a Defender, it is a One_Ten
25th May 2019 1:21pm |
