![]() | Home > Technical > Horn |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17686 ![]() ![]() ![]() |
You will have two horns of different pitches, one by each headlamp (the little grill by each headlamp is directly in front of the horn). These are the ones which (should) sound when you beep the stalk switch.
The alarm will either have its own horn or a battery-backed sounder (BBUS), these are located in the vicinity of the n/s headlamp. Whichever of these you have should sound at the same time as the normal horns if the alarm is activated. It sounds as though both your main horns have failed, or you have a power issue. Access to the horns is going to be really difficult if you can't remove the headlights, I'm afraid. |
fuse 3 in the driver under seat fuse box
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Try separate power source to the horns, they fail regularly and are cheap to replace, Jeff
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
pjh Member Since: 23 Nov 2010 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
Thanks, Dorsetsmith, that's really helpful. Much appreciated.
Do you know where the earth point is located? I wonder if that is my problem given that both horns have packed up at the same time. Many thanks, Peter Defender 11MY USW |
plug C1266-3 pin 3 ground for horn / plug C1264-3 pin 3 ground for horn
and earth header ![]() Click image to enlarge |
Dorsetsmith, you are a star! I'd have never found that!
