Home > Technical > Puma 2.4 Piston Removal
InternationalDBA
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I have a Puma 2.4 engine in a 2008 Defender with 150,000+ miles.
I believe it has small end failure so I am trying to remove the pistons.
Has anybody done this with the engine in place?
That is what I am trying to do but the lower crankcase is stuck to the block and I cannot get it off.
Any ideas?
Post #773864 19th May 2019 12:52pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
You have to remove the bolts/nuts on the big end bearings to remove the piston.
So the sump must come off.
Post #774194 21st May 2019 10:19am
InternationalDBA
Yes, I know that.
I rebuilt a Morris Marina engine with the same problem in 1986.
The problem with the Puma 2.4 is that it has a 2" deep lower crankcase which will not come off.
This is a Ford Transit engine and I have just read on a Transit forum that there is an extra bolt behind the flywheel holding the lower crankcase in place so I have to take the engine out.
I will let you know how I get on.
Post #774991 26th May 2019 6:42am
hank
How annoying! > 110 XS Double Cab
Post #774993 26th May 2019 6:46am
jfh
I hate it when they do that.
Post #774994 26th May 2019 6:47am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Removing the gearbox isn’t a hard job. You’d need this off and the flywheel to fit a new rear crank seal when you’ve finished anyways. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #774997 26th May 2019 7:10am
Puma22
InternationalDBA wrote:
Yes, I know that.
Hi, I appreciate this is an old thread. But did you remove the engine or were you able to get the lower crank off? - I have a cracked piston, but it’s on low miles, so replacing the crank gasket/bears is not my concern.
Post #959073 21st Jul 2022 5:49am
