![]() | Home > Maintenance & Modifications > DIY wheel alignment/tracking |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4800 ![]() ![]() ![]() |
In all honesty, I would pay someone to do it.
I think I payed £40 for a 4 wheel lazer alignment, it made quite a difference at the time (it was a while ago now ![]() However if I was doing it myself I would probably remove the front wheels and clamp two straight edges to the hubs, then measure for parallel ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I tried doing it myself with the measuring to the front and rear of the wheel rim. Got it close but sent it off for a proper check and it was out a little bit. The difference between many thousand miles on a set of tyres.
So in my opinion it’s much more sensible to pay someone to do it proper. Cost me £45 at an ATS place. Took them all of 15 minutes dudeto the brand new sumo bar and drag link I’d just put on. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
Cheers chaps. I hear you but my tracking is out now, which I'd like to sort and in a couple of weeks I'll be doing the Gwyn Lewis drop arm sumo jobbie. Plus I wouldn't mind knowing how to do it anyway.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
The last time I did an emergency tracking job (on a S1 about 30 years ago) all I used was a metal extending tape measure and a helper to hold the end. As far as I know it has still never been readjusted so can't have been too far out!
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2317 ![]() ![]() ![]() |
I use the string method, served me well for the last 25 years. It's quick, easy and accurate enough.
richcl Member Since: 25 Mar 2011 Location: tewkesbury Posts: 25 ![]() ![]() |
I use the string method too.
Just remember the difference between front wheel drive, rear wheel drive and all wheel drive cars when carrying out this procedure. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
I'd like to give this a go too as I have been underwhelmed when having it done "professionally" - steering wheel off centre, vehicle tracking one side or the other, unequal number of turns left and right on the steering wheel etc.. > 110 XS Double Cab
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 ![]() ![]() ![]() |
I used two flat bars and a tape measure to get mine aligned after replacing all the track rods and ends. I got it as close to perfect as I could, but still took it to a shop to get it double checked as I had a wheel out of balance. They said I was still about 1mm out, the difference was noticeable.
The alignment check took 15 minutes and cost £15. |
Mies Member Since: 07 Jan 2019 Location: Lithoijen Posts: 15 ![]() ![]() |
String method. Was conviced fancy laser type stuff must be better until I had a pit-pass for a WEC race at Spa......even Audi was using the string method.
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 330 ![]() ![]() ![]() |
These are fairly useful to do the tracking with. A little limited on how much access you have but as long as you use the same height front and back will get it close.
https://www.screwfix.com/p/harris-trade-ex...gIl1_D_BwE When you buy one SWMBO will get excited and start choosing some paint colours. |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
I use 2 aluminium pipes that fits snugly into each other. The biggest of the 2 has a diameter of about 8mm.
The inner pipe slide out telescopically and I mark on the inner pipe with permanent marker. I measure the distance between the front rims at the rear and front on the same height. Using a straightedge to determine height but a laser can also work. After adjusting alignment, I roll the vehicle back 2m and back to original position and remeasure. I work on a 1mm difference between front and rear, but can't remember if it was +1 or -1mm.. A while ago I had new tires fitted and alignment done, the guy doing the alignment said I was almost spot-on. |
Just walking past wilko and popped in to see one of these:
https://www.wilko.com/en-uk/wilko-extending-pole-1-2m/p/0343127 Only 3 quid, not worth getting a hacksaw out to make one at that price. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
Ive just seem all the British Touring Car Championship teams using the string method this weekend. If it’s good enough for them... 2007 110 TDCi Station Wagon XS |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
Must set mine up... never bothered in the last 9 years/65000 miles.... be interesting to see how far out it is... probably miles out, seeing as I built the axle from various sources
