Home > My Defender > K90
Page 9 of 31 <123 ... 8910 ... 293031>
JOW240725
You wait until you're tempted by a second weekend Defender! There is no end!! Shocked James
Instagram @suffolk_rovers
Post #800477 2nd Nov 2019 3:07pm
Co1
Pretty sure I’ll not be getting a second, although it would give me somewhere to put the B6’s when they come off tomorrow!
Post #800504 2nd Nov 2019 7:02pm
Sulisuli
That’s the way to do it, have two then move the accessories from number 1 Defender to number 2 that’s a cunning plan, now I just need to let SWMBO that I would like a second Defender Laughing 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #800515 2nd Nov 2019 9:17pm
JOW240725
The benefit of two is you should have at least one working at all times! James
Post #800556 3rd Nov 2019 8:34am
Sulisuli
Like your thinking James, not sure I can persuade SWMBO that’s a good enough reason Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #800563 3rd Nov 2019 9:58am
Co1
Fitted today and feeling good. However, there is a knocking from the rear. The top mounting bush doesn’t seem as tight as the Bilstiens that came off, and there is quite a bit of slack. This doesn’t seem right does it? See attached pic. I feel like there should be cup washers either side to squash the bush? What’s the general consensus?
Post #800592 3rd Nov 2019 4:19pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
You need to use 2 of your original washers not bilstein ones 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #800596 3rd Nov 2019 5:41pm
Co1
Cheers! Haven’t got the original, I’ll make some tomorrow. Does the outside one sit up against the shoulder on the bolt, or go past the shoulder?
Post #800598 3rd Nov 2019 5:47pm
Co1
Will I cause any damage doing about 15 miles on smooth roads? Need to get to the workshop to make some washers.
Post #800599 3rd Nov 2019 5:49pm
MJN110
When making up the bottom mount I just made up enough to make the cups snug I thought it would be less stressful on the shock and minimise any side thrust.
I also gave the cups a light coating of silicon grease to ease there preforming. 2016 Defender Landmark 90
Post #800600 3rd Nov 2019 5:52pm
MJN110
I am fairly sure it goes up against the shoulder. 2016 Defender Landmark 90
Post #800601 3rd Nov 2019 5:55pm
Co1
Top man, much appreciated.
Post #800606 3rd Nov 2019 6:13pm
MJN110
Note the washers I used have the bevel profile towards the shock. 2016 Defender Landmark 90
Post #800608 3rd Nov 2019 6:18pm
Co1
Cheers, but not sure I can see from your pic. If the washer was a bowl, would the rim of the bowl be facing the shock?
Post #800613 3rd Nov 2019 6:32pm
MJN110
Yes the bevel/bowl would be facing the shock. 2016 Defender Landmark 90
Post #800614 3rd Nov 2019 6:36pm
