![]() | Home > Puma (Tdci) > Added noise killer and a few extras |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
PLease tell me more about the insulation how and where was it fitted.
Thank you. |
galawaygreen Member Since: 16 May 2011 Location: Lincolnshire Posts: 132 ![]() ![]() |
The product is called noise killer and is from Manchester England.
All the panels are pre cut with adhesive on the rear you peel paper of and stick it on. Quite easy guess the station wagon is more ackward but still not rocket science !!! Diffence is very noticeable not sure if avialable world wide but have a look at there web site, just google noise killer. Cheers |
great thank you.
we had ours done last year very good worth the money 2.4 90 XS
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
I put noisekiller in my 110, it made a big difference, particularly as I have no carpet. Recently I fit some 10 mm soft and light cotton made sheets into the doors and the roof. Made another big difference again and is cheaper than the heavy noisekiller materials which most propably would have issues to stick to the vertical doors. 15mm would fit as well and as the doors and roof is flat and square it is easy to apply. The guys from noisekiller send the stuff abroad as well, it is just a matter of price, you find the contact details on their homepage.
BR Oskar |
flying_low Member Since: 08 Apr 2011 Location: Masai Mara Posts: 19 ![]() ![]() ![]() |
Hi, sorry for the hassle but could you point me to the posts re: 12v socket fitting in the back? really need to do this and any advise much appreciated..? Cheers.. 2011 110 Tdci 1982 Range Rover V8 Classic (Gone) |
what type of Nisekiller kit has fitted? front, rear or both? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hi, It's really easy right hand speaker driver side (uk) remove the 3 plastic screws using the right bit and lift out the speaker housing or just unscrew the speaker and take it out. Behind is a t connector already in place you just connect a 12v socket and away you go, I drilled the hole with a 16mm tank cutter whole job took 5 min ![]() |
Hi fitted front and rear, they no longer put it in the doors or so the chap said. |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I have been dealing with the noisekiller people for about 12 years now. All my previous cars have had their kits.They have always been very helpful too.
Can't wait to start shoving the spacelayer between the carpets, breaking most of the plastic clips, squashing it all back into place with cuts all over your arms - bliss ! |
