- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
No 6
Rear axle casing ABS to 300tdi | |
Hi all
Quick question, I'm replacing my rear axle casing, it's got a dent in it and is also leaking around the weld due to corrosion.
I've got a replacement disco casing and it has the bush for the ABS sensor FTC 1384. Can I knock this out and swap over everything else or do I need to buy anything specific?
It's a 94 300tdi disc brake?
22nd Apr 2019 10:39pm |
