Home > Maintenance & Modifications > Best place to start sound proofing? |
WilkoW Member Since: 09 Jun 2013 Location: Northants Posts: 84 |
Am I missing something here? Surely, when the carpet is replaced it won’t fit correctly due to additional 9mm of insulation or is there additional work required? |
28th Apr 2019 1:14pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
I’m finishing mine in rubber matting rather than caret but there on here have carpeted.
28th Apr 2019 2:31pm |
I deliberately didn't use foam on the floor and wheelboxes due to concerns it would be too compressible. I also think that carpet will do a similar job as the foam, in any case. It's all a slight compromise but if the sides and roof and done to a good standard then I doubt the difference is noticeable. Darren
28th Apr 2019 5:02pm |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 |
Rear arches and floor, and then front floor and seat boxes gave best bang for buck in my 90.
28th Apr 2019 5:27pm |
