![]() | Home > Tdi > 300 tdi overheat & fuel leaking out of cap down car body |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
I think it's 2 separate things.
1. I think the head is toast. 2. The vemt line of the fuel tank is blocked. Rock the Landy sideways and look if the fuel drains out of the filler neck. My old V8 used to push out the fuel until I started doing this. |
Hunky Gibbon01 Member Since: 20 Mar 2017 Location: Dorset Posts: 90 ![]() ![]() ![]() |
Thanks for reply.
Shame if the head is done for. I thought it was ok. I read up if head gasket done then coolant should be white cloudy colour. Coolant at moment is brown which it colour of the coolant. Odd the mechanic didn't pick it up when sniff tested it for exhaust gases. I will rock the landy tomorrow. Thanks |
Sniff test on diesels are notoriously difficult.
Good luck. Hope I'm wrong. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
In additional filled up the fuel tank to full yesterday and there is fuel leaking out from from cap. I have replaced with new cap but keeps on happening
Did you stop filling the tank when the auto shut off at the garage clicked the first time or did you do what so many do easy the filler out a bit and put some more in?. It sounds as if the tank has been over filled and in the current heat there is no room for expansion except through the filler cap. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Yep the auto shut off was used.
I see you point with the heat but not heard of it. |
Update 25 April. Truck runs ok if revs and speed are low.
Auxiliary fan used alot to attempt control of engine temperature. Fuel cap wise seems to have stopped but that's because fuel level is halfway. If it does turn out fuel tank vent is dodgy. Is it difficult to repair/sort? Thanks |
