Home > Off Topic > Any metal workers or fabricators?
Bluest
Can anyone tell me how the thickness of aluminium treadplate is measured? Does it include the tread pattern? 2007 110 TDCi Station Wagon XS
Post #767964 10th Apr 2019 8:45am
ARC99
I have found in the past that it all depends on the manufacturer, some will state the thickness of the plate less the tread pattern and others will include the tread pattern. I have found when ordering steel tread plate that you have to ask the question when ordering. Don't make old people mad.
Richard
Post #767965 10th Apr 2019 8:53am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
When you order you ask for, as an example:
“3mm OP(On Plain) and 5mm OA(Over All)”
That will give you a sheet that is 3mm thick with 2mm ‘teeth’.
Hope that helps. Over the years I’ve probably bought in excess of 100tonnes in steel/stainless steel/aluminium and have always bought on that description from various stock holders
Post #767971 10th Apr 2019 9:26am
Bluest
Thanks for the info. I am embarrassed to ask because I used to be draughtsman and a metals buyer for a sheet metal company, but 15 years out of it, so some of the knowledge has gone. Embarassed 2007 110 TDCi Station Wagon XS
Post #767984 10th Apr 2019 10:33am
nakatanenga
Germany
standard is 2mm/4,5mm WANTED:
SII or SIII in max 1.5k
Post #767986 10th Apr 2019 10:57am
