Home > In Car Electronics > Connecting external leisure battery pack
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I’ve got a greenbox leisure battery box, I’d like to charge this while traveling, the greenbox already has a Car Go split charge relay in it.
I’m aiming to connect via Anderson SB 50s, with one plug permanently fitted to the car.
Question is, what cable should I run from the car battery to my Anderson connector, and what fusing should I go for.
What sort of amps am I needing to deal with between the car battery and the Split charge relay.
Post #767194 6th Apr 2019 1:03pm
DSC-off
Hi Al, I've been following this, hoping you get an answer, because I've been wanting to do the same.
I figured the connection between the 2 batteries should be able to handle the full output of the alternator, should it ever have cause to put it all to the leisure battery.
Something else in the back of my mind said caravan type split charge systems wouldn't handle the full alternator power, so maybe it's not necessary?
I've not found a definite answer and haven't tried anything yet.
Sorry, I've not helped answer the question. Hope someone can enlighten us both.
Cheers!
Post #768179 11th Apr 2019 6:51pm
Al_The_Pal
Just bought a solar panel to keep it topped up on site until I work out what’s needed.
I’ve had a recommendation to a local auto electrician... so hopefully he’ll work it out for us.
Post #768182 11th Apr 2019 7:12pm
leeds
If you are thinking of having an Anderson connector permanent on your Defender I would suggest a SB175 which is rated at continuous 175 amps. That would need 35mm2 cable feeding the SB175. That would mean you could plug jump leads into the SB 175.
Now heavy duty cable you would be looking at about 7 amps/mm2
Max output from a standard alternator is about 100 amps. So assume 50% of that maximum is available for charging the extra battery so that would be about 50 amps
Now fast battery chargers can charge a battery at about 40 amps
Yes am working on high current figures.
This would mean at least 6mm2 cable
Now SB 50 are rated at 50 amp continuous
SB50 are available with either 6mm2 or 13mm2 contacts
Hope that all makes sense, but I do tend to work with good safety factors
Standard chargers work on about 2-7 amps so about 2mm2 cable.
You can do a convertor from SB 175 to a SB 50
HTH and makes sense
Brendan
Post #768190 11th Apr 2019 7:50pm
DSC-off
Thanks Brendan. Will look into those wire sizes.
Cheers.
Post #768356 13th Apr 2019 4:54am
Al_The_Pal
Done. SB175 to SB50 with 16mm cable, probably overkill but found genuine Anderson terminals for that size so seemed appropriate.
Post #772144 8th May 2019 4:38pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Al_The_Pal would be very interested to see some pictures of your finished install as I am thinking of going down this route myself.
Post #774651 24th May 2019 7:12am
