Home > Technical > Could this be causing an ABS issue?
bankz5152
There is some light scoring around the rear drivers side exciter ring on the inside of the brake disc.
Could this be causing my ABS issue? Have the fault code on Nanocom "rear right sensor too low"
 Instagram @defender_ventures
Empire Tuning - Agent
Post #766503 2nd Apr 2019 10:53am
grafty99
I would say it might well be. If its not the ring then it could be damage to the sensor.
Something had jammed in there and ground away at the ring, its likely there will be damage to the sensor as well Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #766511 2nd Apr 2019 12:05pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Looks like something has jammed in there.
I've always wondered what these actually do. Are they essential?
Post #766513 2nd Apr 2019 12:11pm
bankz5152
The sensor looks alright, slight score but nothing that looks really bad.
The are what the ABS sensors read.
Ive cleaned the sensor,, plug and ring issue remains. Has been intermitant since I got back from a very wet Salisbury.
Worth replacing the sensor? Instagram @defender_ventures
Post #766519 2nd Apr 2019 12:30pm
Co1
Can you adjust the sensor to close the gap up? There may well have been something in there that has opened up the gap between the sensor and the castellated disc. This would explain the scoring and the alarm.
Post #766523 2nd Apr 2019 12:38pm
bankz5152
Dont know tbh. Far as I know its just push it in till it stops. Instagram @defender_ventures
Post #766527 2nd Apr 2019 12:57pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
My near side front has always had a problem and my fix is to tap the sensor back in gently with a piece of wood and hammer, don’t overdo it, it resets and works fine until it raises up again. Hope this helps. Regards
Dennis.
Post #769157 18th Apr 2019 10:07pm
