Home > Maintenance & Modifications > Winter / Spring upgrades |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3773 |
Looks good,
Interested about the drive shunt etc as mine currently feels when I lift off the power it 'lurches' hard to explain. What does the new prop shaft 'add' just less play etc? I'm soon to have an uprated roll bar and Bilsteins fitted to mine but interesting to hear about the other mods. Thanks |
29th Mar 2019 2:25pm |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
Cool, like the pedal covers, do the isolaters bring her back to standard height? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
29th Mar 2019 2:29pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Looking great! I want to see the new wheels? James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
29th Mar 2019 2:30pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
@stacey. Needs a good wash
Mine was twisted when I got it, so it does have updated ARB front and rear, and Bilstein b6’s which having driven other D90’s, makes a big difference The springs make it much more stable and planted, I think the isolators do help cushion the spring to chassis bounce, crashing, metal to metal, think all the upgrades have taken all the slack and vibration out of the driveline. It’s very smooth, and gear changes do feel much easier, I do have a slick shift too. @Osloblue. The isolators have probably added 1/4” back, although they have probably compressed with the weight back on. It has lowered it and closed the gaps under the wheel arches. So, I’m guessing it’s dropped just under an inch, but, bodyroll has gone, completely, driving on road is much smoother, bumps and joins in the road as soaked up, so much, much better and the harshness has gone. |
29th Mar 2019 2:41pm |
The Bowlers going on next week |
What does the new propshaft 'do' does that take part of the clunckness out..... |
29th Mar 2019 2:43pm |
The rear halfshafts were badly worn, the rear diff was worn / slack, the rear propshaft was also on the way out, bad UJ. So, hard to pin point what took away the slack, My guess, all of this removed it together.
29th Mar 2019 2:48pm |
Before drop
Click image to enlarge After drop |
29th Mar 2019 2:49pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
How many miles have you got out of the diff? Did you do the output shaft as well?
29th Mar 2019 3:27pm |
It was clonking when I got it at 62K miles... it got worse as now has 71k... yes, replaced.
29th Mar 2019 3:44pm |
Mine is clonking at 65k. Have done he half shafts but to no avail. I think I’ll end up going the same route as you.
29th Mar 2019 3:51pm |
Slack in the propshaft / UJ or the diff is worn...
29th Mar 2019 4:43pm |
UJs are good, I’ll vid the slack in the diff and post in here for opinions.
29th Mar 2019 5:04pm |
You've made some nice mods there. I particularly like the pouches and molle panel on the rear door.
I'm not sure about the springs though - your comparison pic looks like the rear has been dropped by a lot more than an inch. It appears as though the back is heavily loaded Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Mar 2019 7:06pm |
