![]() | Home > Puma (Tdci) > Retrofitting a heated windscreen |
ME!! I taken the signal from C1040-pin 14 and I replicate exactly the original Land Rover electrical scheme. I looked for a female pin "similar" to the original and inserted it on the C1040 connector. It is easy to disassembly and easy to fix in position the pin also. Tomorrow I'll send you a copy of "my studies" if you PM your email. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 20th May 2011 7:40pm. Edited 1 time in total |
my studies
Instrument Cluster Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 20th May 2011 11:06pm. Edited 1 time in total |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
The connector is from the Tyco/AMP MQS family. Land Rover don't supply terminals or connectors separately (dealer's workshops can get some connector shells and some terminals, crimped to 'repair wires', through SPX, but they're silly money) However, VAG and BMW use these MQS connectors extensively and they DO supply spare terminals and/or 'repair wires', which are a short length of wire with a terminal crimped-on at either end. The terminals you're looking for can be sourced from a VAG (Volkswagen, Audi, Seat, Skoda) dealer as a - Terminal - N 907 647 01 (sometimes referenced as - N90764701) ![]() Click image to enlarge or a Repair Wire - 000 979 009 - which is a length of 0.5 mm˛ cable, with a N 907 647 01 terminal crimped on to each end ![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17569 ![]() ![]() ![]() |
Fantastic! Thank you both very much. Once again the collected knowledge of this forum comes up trumps.
Has anyone fitted their own glass? It looks quite straightforward but is it better to get a "professional" to do it? Where is the best place in the UK to buy a heated screen - or does anyone here have one for sale? |
toshers Member Since: 19 Sep 2010 Location: Inverurie Posts: 120 ![]() ![]() ![]() |
You can get them from HERE
Blackwolf posted wrong link, here the correct my studies Instrument Cluster Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 ![]() ![]() ![]() |
I can supply the MQS wires through the site shop - http://www.disco3.co.uk/shop/index.php?act...oductId=37
