![]() | Home > Puma (Tdci) > Water leak from engine oil cooler. |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
I did have oil going in cooler system. I did not try to repare the oil cooler and replace it with a Ford part , oil filter is different. Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
How like Land Rover.
After finding someone who has the knowledge and the willingness to work on a Land Rover S.H.M.B.O. dropped it off this morning. Called after 2.00pm and they have inspected it at first the could not see a leak until the receptionist told the mechanic that our drive is on a slope, he lifted the rear end and hey presto Niagara falls, he agreed that its a seal that has gone which should cost at the most a couple of quid only problem is the seal is not a replaceable item that either land rover of Ford list and its a special size , the only way to replace the seal is to but the whole unit which is more £££'s ![]() We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Another learning day.
If anyone is interested. The engine oil cooler which is mounted on top of the oil filter, has a thermostat fitted to the water side and one on the oil side . The one on the water side is bolted to the oil filter, assembly, has a rubber O ring seal and comes off at an angle. The rubber O ring on mine failed and was leaking about 2 Gallon of water per day, having now got the failed part home and had a good look at it its a wonder that it ever sealed in the first place. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 ![]() ![]() ![]() |
Thanks for posting this, how old is your TDCI and whats the milage? Never seen this issue posted before so maybe
you have just been unlucky ? |
Vehicle was first reg in 2008 and its done approx. 85,000 miles. Don't make old people mad.
Liam Murphy Member Since: 29 Jul 2020 Location: South Wales Posts: 95 ![]() ![]() ![]() |
Yes, I'm interested! Mine has developed the same problem, a day after getting it back from having the clutch replaced. Can you remember what the replacement rubber o ring part number / brand was by any chance? Cheers! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8201 ![]() ![]() ![]() |
My 2011 130 has had replacement cooler fitted for this reason, came with it like that when I purchased. Interestingly the replacement cooler is later type so mine now takes later spin on filter not earlier insert type. Cheers
Tumbiri Member Since: 01 Nov 2016 Location: Caribbean Posts: 52 ![]() ![]() |
quote="Liam Murphy"]
Yes, I'm interested! Mine has developed the same problem, a day after getting it back from having the clutch replaced. Can you remember what the replacement rubber o ring part number / brand was by any chance? Cheers![/quote Liam, mine has just developed a coolant leak at the oil cooler thermostat (62K Km). Were you able to replace the O-ring on your thermostat and if so, do you have a part number? Cheers. |
I changed the thermostat itself, it's only £16.99 for the unit
Part and number is: OEM Oil Cooler Thermostat For Land Rover Defender 2.4 TDCI Puma - LR005894G https://www.ebay.co.uk/itm/OEM-Oil-Cooler-...SwLy1d61yH |
It was done by a garage, I will have to have a look through the paperwork to see if they put the part number on. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
