- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
dorsetsmith
1.if not isolat all Indicator lamps unplug flasher unit from its base, unplug green plug from the alarm unit also unplug Hazard switch and unplug your dash and use multimeter to test the wiring for ground short
2. replug in items one at a time re test for short
17th Mar 2019 7:20pm |
