Home > In Car Electronics > battery charge
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
battery charge
Hi, forum,
I have installed new optima redtop into the defender. I charged 2days ago and on final charge, it showed 13.3V. now it shows 12.6 - I pulled the main fuses so there was over this time no power via the fusible links etc...
only thing I have is a simple voltmeter which shows voltage ...
is this drop expected (optima talks around 12.4 for red top) any pointers?
Post #762006 5th Mar 2019 10:57am
landy andy
That is the correct voltage for a standing battery to be in my opinion. The 13 it showed before was because of the charge, not its resting voltage. But I’m sure an adult will be along soon to give better advice.
Post #762027 5th Mar 2019 1:25pm
ARC99
Re: battery charge
itolond wrote:
Hi, forum,
This may help https://haynes.com/en-gb/tips-tutorials/how-test-car-battery Don't make old people mad.
Richard
Post #762147 6th Mar 2019 10:35am
Dave-H
THIS ...
A fully charged healthy battery will read about 12.6 -12.9 volts, you will get higher readings a few hours or more after charging/driving Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #762151 6th Mar 2019 11:09am
