Home > Technical > broken glow plug puma
fr3dg1
Switzerland 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hello,
despite being very cautious it seems that 2 of my glow plugs might be broken
I sprayed wd40 a week prior to remove the plug, I warmed up the engine, I used a torque wrench set on 20NM
2 came out very easily but 2 other wont pull out, they dont look broken, the tread is out but they wont pull out.
they dont rotate easily, I still need to use the wrench to rotate them
the core looks it is still attached to the outside body, I used a open wrench to check if the core was rotating simultenously when I was unscrewing the body
can it be the plug is still in 1 piece but the hole is just narrow and some gunk preventing me to pull the plug?
what are my options now?
thank you in advance
Fred
Post #761731 3rd Mar 2019 6:38pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I had the same problem and I managed to remove mine by pulling on them and twisting at the same time. Pulling them up and outwards with a smaller spanner whilst turning with a socket. 1953 80"
1987 mini city e
2011 90"
Post #761958 4th Mar 2019 11:40pm
landy andy
Normally it’s burnt carbon deposits on them that stops them coming out. The trick is to be able to pull enough, and hard enough, without them breaking. That your time would be my advice.
Post #761962 4th Mar 2019 11:59pm
grafty99
Lots more penetrating fluid and lots of turning with gentle pulling pressure Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #761979 5th Mar 2019 8:48am
Naks
One of the indies I know has a trick for this: prior to any work being done on injectors/glow plugs, he gets the customer to drive around for a few days with some 2-stroke oil in the tank.
that way, the injectors/glow plugs come out more easily --
Post #761984 5th Mar 2019 9:22am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Always run mine with 2 stroke oil in the tank. Thumbs Up
Post #762019 5th Mar 2019 1:44pm
