Home > Puma (Tdci) > Rubber grommets in bulkhead in center of wiper blades
Dexterdog
Hi,
Rubber grommets in bulkhead in center underneath each wiper blades
Anyone know what these are for ? Obvious thing is washer jets but if that is the case then why have just one central washer jet of such a poor design if the holes are already there for a jet under each washer??
Was thinking of splitting the washer jet supply behind the dash and possibly direct it into these two holes to giver a washer jet under each wiper blade but just wanted to check if anyone knew what they were for ?
Post #758430 13th Feb 2019 5:55pm
macfrank
spot the difference to yours Wink
Post #758432 13th Feb 2019 6:04pm
nitram17
yep beat me to it Thumbs Up you see but dont observe Rolling with laughter
Post #758434 13th Feb 2019 6:05pm
Dexterdog
Ahhhhh....you made a monkey out of me Very Happy Very Happy Very Happy
Thanks for responding, just got to work out now if my OCD will let me have two washer jets that are off center..... sad I know !
Post #758437 13th Feb 2019 6:11pm
Dexterdog
Just thought it through a bit more......
Does anyone know if there is anything (such as the bar connecting the two wipers) behind these grommet holes that would snag on washer jets (tubing, rear part of washer jet etc).
It seems such an an obvious fix to the washer jet problem that we all have to use these that if it were that simple others would be doing it already which makes me think I am missing something ??
Post #758440 13th Feb 2019 6:17pm
Nope, you're not missing anything. Here you go - a bit of light reading for you:
https://www.defender2.net/forum/topic19806...win+washer
Suitable for all models - the only difference is in getting into the dash. Darren
Post #758453 13th Feb 2019 7:26pm
donmacn
I think this is an established mod - using both those blanks to have twin washers. I know I've seen it on here before.
Edit - Darren got there ahead of me, and better too! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #758454 13th Feb 2019 7:26pm
Retroanaconda
Putting washer jets there is a very common modification and well worth doing.
I must have done mine 10 years ago, and have never had to touch them since. Uses far less fluid too, as you don’t have to spray for ages waiting for the wind to blow the water over the screen.
Post #758455 13th Feb 2019 7:27pm
Mariner
Ireland
I did the twin jet mod on mine today. 200Tdi
Post #758467 13th Feb 2019 8:19pm
Dexterdog
Awesome, thanks for all the help (especially the link to the previous thread and the pics)
Post #758569 14th Feb 2019 9:59am
flyingfab
France 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
Hello,
My parents used to have an early (1983) Land Rover One Ten when I was a child. I remember that there were two separate screen washer jets, each of them being located in the holes you are talking about. Nothing was fitted in the centre at this time.
They were fitted exactly like on this beauty :
The washer jets themselves looked like this :
I believe this combination was only found on the early 90 and 110. As far as I remember, this was working quite well (apparently, Land Rover decided this was working too well, so changed them for the crappy single washer jet we all know Laughing )
Cheers,
Fabien
Post #761793 3rd Mar 2019 10:58pm
HardCharger
I thought that the blanks are for the holes done during the production of the firewall so that the wipers can be for left had drive or right hand drive vehicles as required? Once the corresponding wipers are used, the other two holes are plugged. Or did I not understand that correctly.
As for the washers, these plugged off holes CAN be used for washers too but I understand that you have to have a stronger pump in the reservoir to get a decent spray for 2 washers.
Post #761795 4th Mar 2019 2:19am
Retroanaconda
Yes they are the LHD wiper holes.
Standard pump runs two jets no problem at all.
Post #761806 4th Mar 2019 7:30am
On the very early vehicles, they did indeed have two washer jets, which used the holes provided for the wipers when the vehicle was handed. This was similar to the arrangement on the Series III models and I think used the same jets. Later, they added a fifth hole in the centre and fitted a single twin washer jet instead, and then blanked off the surplus holes. I think this change occurred around '87/'88. Darren
Post #761812 4th Mar 2019 8:08am
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
What size tubing is needed? Thanks
Post #761890 4th Mar 2019 4:50pm
