Home > Technical > 2.4 Troubles
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
2.4 Troubles
Hello, I am after your combined wisdom, 2.4 tdci remapped with a BAS map, new injectors, MAFF and VCV with all correct learns a couple of months back. Now we are getting momentary loss of power and then picks back up and a bit of a surge and when the power loss happens the temp gauge swings to hot? Then switch off or returns to normal. Coolent level is good. I am at a bit of a loss as no codes are showing on the id tool.
Post #757471 9th Feb 2019 7:57am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Check tightness of relays under drivers seat, also check the earth straps.
Post #757473 9th Feb 2019 8:08am
LR90XS2011
Feed back on here regards BAS is good why dont you give them a bell DEFENDER 90 TDCI XS,
Post #757479 9th Feb 2019 8:34am
