Home > Off Topic > C-tek charger and a compressor
Caterham
so I need to pump something up in the house to 3bar......
using a foot pump is proving painful and the item is up in the air and my little chicken breast pecks are done for.....
anyone see an issue with rigging up the c-tek charger onto the 12v compressor that typically pugs into the 12v cigar / socket to do the pumping?
Mr. Green
Post #757099 7th Feb 2019 4:41pm
jst
Not enough current from charger. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #757100 7th Feb 2019 4:47pm
Caterham
doh.
erm...does that depend on the charger. I think I've got the 7amp jobby.
.....just checked the compressor it's - 10amp Sad
Post #757104 7th Feb 2019 5:03pm
IIRC my 12V compressor (ARB twin) pulls around 60 Amps when running. I doubt that you'll run any compressor of a charger, although I suppose you might if it is a accessory-socket compressor (although one of those once melted the socket in my Disco2).
You could take the battery out of a vehicle and use that. Alternatively you could pressurise a receiver of some kind at the vehicle and then take the pressurised receiver in the house.
Post #757107 7th Feb 2019 5:25pm
miker
OR drag that spare car battery in the garage/shed out, connect the charger to that for an hour or two, then run the compressor off that.
Post #757109 7th Feb 2019 5:31pm
hank
What is it, expansion vessel? Get yourself a hand bicycle pump? > 110 XS Double Cab
Post #757112 7th Feb 2019 5:41pm
lohr500
Or treat yourself to a small mains compressor.
Lidl have some in next week if you can wait. And they have a 3 year guarantee. Not really big enough for powering hungry air tools, but handy for blowing up tyres or interior pressure vessels Very Happy
https://www.lidl.co.uk/en/MiddleofLidl.htm?articleId=20205
Post #757124 7th Feb 2019 6:16pm
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I have the Suaoki U10 L.I. Jump Starter with a 12v cigarette lighter adaptor, it powers my compressor easily and I no longer have to plug it into the car and drag the cable about.
I’m sure it would do the job.
You can also get 240v to 12v transformers for powering portable fridges that has the cigarette plug and that would also work.
Post #757134 7th Feb 2019 6:44pm
Caterham
Very Happy
thanks guys. I suddenly remembered where I could get hold of an old car battery (save me taking it out of the car).
anyhow grabbed it hoping there was still some charge in it and yes with the help of my daughter operating the compressor (a Ring jobby - I'm not suggesting they're great but for the cost and occasional use I reckon you could do worse) and me hold the cigar / aux plug against the battery and a long screw driver - hey presto job done.
didn't have a suitable bike pump. and yes it was for an expansion vessel.
had some bad luck with em. the first one that was installed didn't last too long and if I remember right it was for vertical installation but was installed horizontally and this the second one hasn't been in long...turns out the valve was leaking and just needing tightening up. Thumbs Up
hopefully no more water leaks now Thumbs Up
Post #757137 7th Feb 2019 6:47pm
