Home > In Car Electronics > Help locating Flasher Relay for LED bulb upgrade
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Just ordered a wipak kit, see it comes with a new adjustable flasher... can someone tell me what relay I must swap out?
Post #755388 1st Feb 2019 2:37am
PCM
Top left as you look at it. I did mine a few weeks back. My original relay fell into bits when i removed it and mine is only 5 years old.
The 99 one nest to it is the programmable washer relay. Well worth it for a tenner for intermittent wipers. Check the forum for info.
Post #755389 1st Feb 2019 3:05am
big110
thanks for that. I did the wiper relay mod, been fantastic. So this is under the dash, not under the seat box correct
Post #755390 1st Feb 2019 3:06am
PCM
Yep. Just next to it. Pop it out and pop the other one in.
I was told to change all the bulbs first to LED then turn them on as the relay might have an issue with the two different types of lights. Can't see why so tried mine after each bulb change. Worked fine.
If one doesn't work the wiring is probably wrong on the vehicle side. LEDs are directional. The originals aren't so wiring may +ve -ve need to be swapped.
Post #755391 1st Feb 2019 3:13am
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
My recent Wipak kit came with a coloured instruction page showing the relay that needed swapping. Although the clicking when indicating the old relay made also narrowed it down Rolling with laughter Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #755392 1st Feb 2019 3:58am
big110
instructions were for TD5 mate, as were all the pictures...
Post #756548 5th Feb 2019 5:35pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
I did this yesterday, massive improvement, I’d recommend getting a set that looks stock since they are so easy to remove, my flasher unit was behind the dash on an 05 2005 TD5 90 CSW XS
Post #762133 6th Mar 2019 8:13am
benniferj
Turn on the indicators and listen for the ticking, follow it, touch the relay, youl feel it ticking.
They are in different places on different revisions of the car!
Post #762137 6th Mar 2019 9:11am
