Home > Wheels & Tyres > swingaway rear wheel carrier
wurzell
hi all Very Happy can i please have some recomendations regarding good quality swingaway rear wheel carriers there seems to be quite a few different types on sale, any help with this would be great thank you Thumbs Up paul n tash
Post #70608 12th May 2011 8:06am
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
I saved up all my pennies and went for the Alisport / Sonic model. Expensive, yes, but as I have a double cab, did not want to bolt an arm through the tub.
The one I have is entirely mounted on the rear crossmember and is a serious bit of kit - WAY over engineered. 2001 TD5 110 DCPU in Bonatti Grey
Post #70611 12th May 2011 8:32am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Mantec rulez!!!
I am using my second swing away on my second Defender. Always Mantec.
http://www.mantec.co.uk/productdetail.cfm?...E1BC616A94
Post #70614 12th May 2011 8:43am
leeds
Just bear in mind that not all swing away wheel carriers fit with all rear bumperettes etc. Check for compatability.
Some wheel carriers have wheel centred on door some shift them sideways towards offside.
Ensure you get a wheel carrier with grease nipples fitted.
Then do you want the wheel carrier galvanised prior to powder coating? High lift jack mount?
The Kaymar is a good wheel carrier but is expensive, I think it might be even more expensive then Sonic/Alisport one which certainly appears to have a good reputation.
Then you go to Safari Equip, Mantec etc. I would avoid ebay elcheapo specials however.
On the back of our 110s we have Safari Equip ones (moves wheel off centre) One has seen some serious use over 8 years and is still good.
hth
Brendan
Post #70616 12th May 2011 9:03am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Second vote for the Sonic Carrier. It's so sturdy mine deflected an over-eager Peugeot with barely a scratch Thumbs Up
http://www.defender2.net/forum/topic2179.html Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #70620 12th May 2011 9:37am
Nakatanenga Wheel Carrier allday
Tried the Sonic but fed up with unlatching all the time The Sonic one is well made and thought out
Post #70622 12th May 2011 9:43am
JSG
I put a Mantec one on the 90TR - been very pleased with it so far. John
2011 Tdci 110 CSW XS
Post #70623 12th May 2011 10:00am
BigMike
The new safari equip one is VERY solid (and fits with their own bumperettes) but not out in the market yet. its far more robust than the mantec one. It's similar to the naka one in terms of thickness of steel.
I've seen a sonic one which is also excellent though the downside is its far more money than the others. I like the kaymar one too but the unlatching of both would be a pain as far as I'm concerned and for a non-pick up I'd have the new SE one or the naka.
Post #70625 12th May 2011 10:02am
Third vote for Sonic - can't be faulted. Mine needed a little bit of customising to allow the rear flap of my Ifor Williams top to clear the 285 on the carrier (an easy mod, details on request).
Post #70630 12th May 2011 10:43am
pannawonica
Australia
I have a Kaymar, it is robust and user friendly. Generally I forget about the price , but the perception of quality remains.
However if you are not subjecting your vehicle to corregations suppose anything that takes the weight off the back door
will be fit for perpose.
Post #70646 12th May 2011 12:44pm
Zagato
Ta for that Mike, I have just called SE and he can supply the new type that just fits on the chassis with about a weeks notice. He hasn't put pictures up on the web site as he hasn't got it sorted yet for all vehicles but they are available on request. If they are as good as the bumperettes and snorkel I will go with them Thumbs Up I like the idea that it is fixed to the chassis only so you don't have to drill anymore holes in the bodywork Thumbs Up I'll have to wait a while before readies are available Shocked
Post #70662 12th May 2011 1:41pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
vote for mantec
Post #70664 12th May 2011 1:47pm
Steve in Germany
Wales 2000 Defender 90 Td5 CSW Alveston Red
How much are we talking Zag
Post #70666 12th May 2011 1:51pm
Zagato
£295 + VAT It attaches to the crossmember and uses existing holes in the rear door.
How much is a Sonic, Mantec etc folks Question How does it compare price wise?
Post #70668 12th May 2011 1:58pm
110SEB
Tat SE one sounds good Zag - i'm keen to see pictures of it, as this is something that I would like to buy for the Tank.
Post #70670 12th May 2011 2:02pm
