![]() | Home > In Car Electronics > Single din recommendations |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I really like these as well but think there around £1200
paulas Member Since: 23 Nov 2018 Location: cheshire Posts: 23 ![]() |
Yeh I have had 2010 Puma for 7 years, gradually doing improvements over the last year including the sound system. Think I will take your advice, thanks |
Defender Fun Member Since: 03 Feb 2019 Location: South East Posts: 64 ![]() ![]() ![]() |
Hi thank you for your advice PM sent Kind regards |
farmerben….I bought the Focal ES100 k speakers as you suggested. Got to fit them now. From your experience is it easy or is there anything I should know? Also where did you put the crossover units?
Cheers, Paul |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I'm removing my single din from a puma 2014 tomorrow.
It's the alpine DCE-133BT that is fitted to the XS models. Has bluetooth, CD player and hands free etc.. I was going to keep it to gather dust in case I ever wanted to make the car base spec again, but i could let it go if you're interested? |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 ![]() ![]() ![]() |
I have zero experience with car audio but the fitting of the speakers was dead simple - there’s a good documentary on the Mud website to help with installation. I just found a spot behind the dash inside the speaker holes and used strips of double sided sticky rubber to fix to the inside. https://instagram.com/bentheoandrews |
