Home > Camping, Caravanning and Holidays > Led internal strip lights for off road camping trailers
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Looking for good quality strip Led lights, 40 to 50cm for internal lighting, 12v, can anyone recommend makes / suppliers.
Must have on / off switch as well.
Labcraft seem to be the favorite,just would like some advise.
Post #752457 19th Jan 2019 6:45pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
looking for some myself.
have a look at.mobile centre big range there 110 xs s/wagon
s3 swb soft top
Post #752466 19th Jan 2019 7:13pm
Sulisuli
Labcraft lights are extremely good, I have a scenelite S18 as a reversing light and if their interior lights are as good you weren’t be disappointed Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #752468 19th Jan 2019 7:21pm
davew
If it's just for general fixed lighting, LED strip lighting is the simplest and most versatile. You can get a 10 metre reel of single colour waterproof for about £20. It runs off 12v and can be cut to any length.
If you're wanting something a bit different you can also get the RGB versions which, with the use of a control box and remote can be configured to just about any colour. Usually about £25 for a 10m reel.
This is the interior of our trailer during conversion that shows how well every corner is lit up by the multiple LED strips...
The strips are mounted to each roof bar, on the back side so they don't dazzle. http://www.yorkshireoffroadclub.net/
Post #752497 19th Jan 2019 9:08pm
Rashers
Mounting these strips onto something metallic is a good move to increase their life.
Commercially, they are usually run in an aluminium extrusion. This acts as a heat sink to disapate the heat. We sometimes insert a plastic diffuser into the extrusion to diffuse the light.
There is a real misconception that LEDs run cool and all is ok. They actually aren’t very reliable in elevated temperatures and thus mounting them in a metal extrusion, or as davew has, on a metal surface, will go a long way to prolong the operational life.
LED strip is fantastic stuff. It’s used all over these days for getting lighting in areas where lighting couldn’t be fitted in years gone by. As a rule of thumb, with all things, the more you pay, the better quality the LED chip sets are likely to be.
Cracking product. Thumbs Up
Post #752501 19th Jan 2019 9:24pm
peterl
Thanks for that, will try mobile centre for labcraft and will try the strip roll lighting, change in colour when camping may be good.
Thanks
Post #752519 19th Jan 2019 10:28pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I've had loads from https://www.ultraleds.co.uk for various vehicle and house projects and been impressed with their service and quality. They also sell matching aluminium profiles and several types of diffuser. You can then make lights of exactly the length needed for your trailer. I've used the waterproof strip in mine - directly stuck onto the inside of the aluminium side/roof flaps.
As mentioned earlier - the brighter LEDs run surprisingly hot, so attaching the strip to something with thermal mass can only be a good thing for their longevity.
Post #752534 20th Jan 2019 1:12am
