Home > 130 > Relocation cone for 130? |
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 |
I popped one of my rear springs out recently while off-roading, I managed to jack it up with the high lift and relocate the spring back where it should be, but the helper springs top retainer was lost in the process.
Before I buy another standard helper spring upper retainer are there any options for relocation cones or anything like that for 130’s that work with the helper springs as well? Here is the standard top retainer for the helper spring: https://www.island-4x4.co.uk/coil-spring-u...-5364.html Thanks @tab.travels on instagram Defender 130 2.2 TDCI Defender 90 TD5 80" CCV Trialer 4.6 V8 (14CUX) Stage One V8 109 - 3.5 V8 Stage One V8 109 - 4.6 V8 (GEMS) - in progress Range Rover L322 4.4 TDV8 Freelander 1 2.0 TD4 |
16th Jan 2019 1:58pm |
