Home > My Defender > Fuji 110 LS3 build
Page 38 of 61 <123 ... 373839 ... 596061>
Stebo
Northern Ireland 2011 Defender 110 Puma 2.4 XS CSW Galway Green
Coming together well. That's a class vid from Ged too
Post #881164 26th Jan 2021 8:37pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
I think the front end looks much cleaner without DRL bumper. Less is more an' all that.
I remember following your last build thread where you tried loads of options and then paired down to what you thought worked best. The result was fantastic but IMO this build is another level. So impressive. WARNING.
This post may contain sarcasm.
Post #881166 26th Jan 2021 8:48pm
mcma1
Thanks ^.
I have Laser Triple R's on the transit and the output from them is impressive so I knew I would miss the ST4's in the grille i recently sold.
The equivalent linear unit to the transit lights are the Linear 12 15" so I am adding 2 of them to the rack.
https://www.lazerlamps.com/linear-12.html
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #881266 27th Jan 2021 10:28am
Linds Hanson
There is no difference in light output/beam with the ST4s mounted behind a mesh grille and it makes them a bit more stealth
Post #881318 27th Jan 2021 2:16pm
mcma1
Got on to the new lights this evening.
Mounted them first using the top fix brackets with SS fixings sunk into the T channel at each side.
Then remove the front cross member from the rack and drill 2 holes.
Feed the loom thru the cross member
And then a single connector attached in behind the passenger clamp.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #881657 28th Jan 2021 10:33pm
SN
I've just sat and read this entire thread and all I can say about it is that its been absolutely awesome. Thumbs Up
That V8 sounds gorgeous and I bet you're going to have some fun at the traffic light grands prix. Whistle
Off Topic slightly, I'm amazed the quality you're getting out of your 3D printer - I have one and I've tended to use it in speed-over-quality mode so quality's not been good enough for in-cab exposure - have done the switch bezel thing on last vehicle but time for me to rethink, especially if I want to put something in my forthcoming L663 Whistle Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #881663 29th Jan 2021 12:20am
mcma1
Went for a drive today. Better brakes on my granny’s bike so must get them firmed up in the morning but apart from that all seems well. Going to bring her home tomorrow. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #881787 29th Jan 2021 6:21pm
Co1
mcma1 wrote:
I was lucky, had vouchers so they had to sell me one. It’s actually fully machined for them, branded on the rear etc. I thought it was just a normal Mota they added a boss too.
Managed to get hold of a 14” version. It helps just living down the road from twisted! Does the front boss just pull off or is there a knack to it? I don’t want to end up chewing up one of the edges.
Post #881817 29th Jan 2021 7:41pm
mcma1
Have to say my favourite part of the drive was the new steering wheel, better that the startech.
Yes a wee spray of oil onto the splines, let it sit and a gentle tap should free it up. Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #881821 29th Jan 2021 7:49pm
mcma1
Good to have it back home. Have the first 100 miles run in and so far so good. Brakes are getting better, slight rattle from exhaust on the mud flap bracket but i was expecting that. Need to adjust the gearbox cable to get tiptronic to engage.
I got the front cubby lid printed so I can now get them covered, although I might leave it a while in case I think of something else I might add... Also fitted the rear seat heater switches, same place as before.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #882189 31st Jan 2021 4:15pm
JOW240725
Seriously envious, looks amazing! Bow down James
Instagram @suffolk_rovers
Post #882192 31st Jan 2021 4:38pm
Sulisuli
Andy what’s your thoughts on the new Lazer linear lamps? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #882193 31st Jan 2021 4:38pm
mcma1
Not actually hooked them up yet. I think I am going to make a nice wee fuse board under the rear cubby, keep all the LS loom, modules etc in the main battery box and then the other bits I add all back in the rear. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #882199 31st Jan 2021 4:55pm
Sulisuli
Will be interested to know your thoughts, they look the usual high quality from Lazer. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #882202 31st Jan 2021 5:00pm
Co1
Very subtle for the rear heater switches. Nice work 👍
Post #882208 31st Jan 2021 5:22pm
