Home > Tdi > oil light |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
on start up the oil light stays on for a few seconds from cold , ok when hot , anyone got a idea why ?
13th Jan 2019 6:42pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 521 |
Cheap oil filter with no non return valve ? Wrong grade oil - too thin ? Goosed oil pump ?
13th Jan 2019 7:40pm |
many thanks , sounds like the pump then out of the 3 .
13th Jan 2019 8:07pm |
white110 Member Since: 09 Dec 2017 Location: wales Posts: 10 |
low or lowish oil level
14th Jan 2019 7:38pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Replace the sender unit, cheap as chips, bet it cures it! 'Volvo XC 70, taking the rough with the smooth’
14th Jan 2019 8:49pm |
never thought about the sender , anyone got a part number .
14th Jan 2019 9:55pm |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 |
Sounds like it could be the sender,probably the cheapest part to change first!
Stephen. |
14th Jan 2019 10:04pm |
anyone got a part number \/
for TD5 https://www.lrworkshop.com/diagrams/land-r...r_53224#18 and PRC6387 for TDI 200 / TDI 300 Last edited by dorsetsmith on 15th Jan 2019 8:45am. Edited 1 time in total |
14th Jan 2019 10:24pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
Not sure about the Puma motor but on a 300Tdi, the oil light being on is to indicate that the sender is f*ed, about 999 times out of 1000. I have replaced at least a dozen senders on various vehicles I have owned, they went through a particularly bad patch in the early 2000s where every time the sender got wet, it would let water in and kept the light on, I think I probably had 4 or 5 in the space of a year. Definitely worth changing before looking any further. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
14th Jan 2019 11:07pm |
Thanks Gents, I order one today.
Yes it is the 300tdi. |
15th Jan 2019 1:29pm |
thanks , ordered one now so will fit and see.
16th Jan 2019 7:20pm |
Have you fitted this yet? Did it work? 'Volvo XC 70, taking the rough with the smooth’
23rd Jan 2019 8:07am |
nope it didn't
12th Feb 2019 6:42pm |
Stripygitface Member Since: 16 Sep 2014 Location: Kent Posts: 79 |
Check the dipstick tube hasn't moved when I had a 200tdi, had the oil light come on at tickover, turn out the dipstick tube had been pushed down furhter into the engine, hence dipstick level was correct, but actually engine oile level was low.
13th Feb 2019 7:47am |
