Home > Puma (Tdci) > defender 2012 replacement battery
Portafilter
Australia
hey All. i have a 2012 2.2 110 with an original battery. after about a week-10 days of sitting idle battery is too flat to start engine. Im assuming the battery, at 6 years old, is just plain cooked. Looking at replacing the battery with Varta 830CCA 100AH model.
However ive just been told i need to reset the ECU or tell the battery charge system a new battery has been fitted. Is this correct? personally i cant see the humble defender being that smart..
Post #749932 8th Jan 2019 11:40am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Defender 2.2 2012
I did have a flat battery in the summer on the beach.
The alarm was on and impossible to stop her.
Fortunnaly a people did have cables and I was able to start the engine.
There was a Renault garage not far and they had a similar battery.
Strange, no light or information on the dashboard.
But later I did take off the negatif on the battery and when put it again, everything was ok.
No more to do
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #749940 8th Jan 2019 12:10pm
Merlin
Just bought a new battery from Halfraulds. Their last one only lasted 8 years. 5 year guarantee. Have a search. Peter
Post #749956 8th Jan 2019 12:56pm
Portafilter
Australia
scangauge power drain
thanks for the help.
ive replaced battery with no issues. however is find the Scangauge i have installed seemed to be sucking a fair bit of power around 130mA. if i unplug it current drain drops to around 26mA so under the 30mA recommendation from manual.
anyone else found this with an installed scangauge?
Post #750119 9th Jan 2019 6:53am
