![]() | Home > Td5 > defender 110 td5 2003 major electrical problems. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Check your fuse box for water incursion, also check under the seat at the ECUs and relays for water incursion. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2960 ![]() ![]() |
If the heater drain plug is blocked it could be that the heater air intake filled with water and got into the motor causing it to stall.
This happened to mine, fortunately l realised before the motor burnt out, but it did smell a bit. |
NoFuel Member Since: 19 Jun 2018 Location: Pirkkala Posts: 6 ![]() ![]() ![]() |
Both fuseboxes are dry and in good condition, also drainplug is ok and blower motor is dry.
Any other suggestions? |
check earthing battery to chassis to transfer box and chassis to bulk head
also is it dry behind the dash ? ![]() Click image to enlarge |
I added alternative earthing point (chassis -> bulkhead). earthing point from battery to chassis was ok.
I did measure all earthing points and they were ok. I checked that blower motor is functional applying current straight from battery. when testing blower motor from inside (wire from black to green connector) dash lights were glowing. When I removed fuse number 18 and 19 glow got weaker. I put fuses back and glow got brighter. I measured all fuse block slots for shot circuit and all ok. am I missing something? |
