![]() | Home > Puma (Tdci) > MAF sensor |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 751 ![]() ![]() ![]() |
So how did you retrofit a fuel pick up & float assembly with pump to work with the 2.4?
So how did they wire the in-tank pump? Is it on all the time or does it just work with the glow plug cycle or something?
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
Sorry no idea
Hi kaney, would it be possible for you to ask your shop on how they did it? It will greatly help those of us here with 2.4 Pumas considering this modification to the fuel system as we do not have the pump in the pick up assembly.
