Home > Puma (Tdci) > Wont start
SVX90
United Arab Emirates
Wont start
Right!
Parked my car last night. Everything was normal. went to sleep. woke up. Got in my car. Tried to start the car and nothing. It wont start.
It not the battery I am sure
its the ignition key. It a bit loose and the steering wheel is free.
what do i do?
Post #70145 8th May 2011 10:49am
MK
check on the the battery terminals. Or lock and unluck 3 times. Thumbs Up Puma 110" SW
Post #70147 8th May 2011 11:04am
SVX90
Thanks for the reply, but unfortunately I already tried that
Post #70148 8th May 2011 11:06am
Lorryman100
When you say it won't start, does that mean nothing at all or does the starter turn? Do you have any dash lights on? If you do, do they dim when you try to start? As the key is loose in the ignition have you turned it to the starter position and wiggled it too see if it gives a brief connection? If you have a nanocom isolate the immobilizer and try to start it. If not try the DKC code and see if it will start. Other options are to put a dc clamp meter on the starter and see if there is any amperage present when starting but agree with you that it is probably the ignition module/ immobiliser and you should call out LR assist or contact dealer.
If it is a faulty ignition there is a way to start the landy without the key once the immobilizer is isolated but not going too say on an open forum Whistle However it would show if it was the ignition module at fault Thumbs Up It is a bit of a strip down job but if you have a nanocom evolution and want to try it pm me.
HTH Brian.
Post #70149 8th May 2011 11:52am
mse
Try the other key and remote Thumbs Up Mike
Post #70189 8th May 2011 6:43pm
