Home > For Sale & Wanted > [Wanted] scrap defender xmember
pressbrake
United Kingdom 1990 Defender 110 Other SW Fuji White
hello I need a scrap but intact defender x members in both non td5 and td5 flavours. (must be gen)
I used to make crossmembers but I threw all the jigs away a few years ago. On visiting the laser cutter for the first time since I was met by a dozen blanks with my name on and the need to purchase to be friends again. This was enough money to need to make them up hence this request!
regards
Post #748363 31st Dec 2018 9:56pm
DOOFER
I can't help i'm afraid. but good to see you back again. my crossmember and front bumper are still going strong!! DON'T PANIC
Post #748371 31st Dec 2018 10:38pm
pressbrake
Thanks, but it’s a short term thing, I’ve got a real job now!
Post #748375 31st Dec 2018 11:01pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
My 110 HD TD5 rear cross member is due replacement imminently, if you don’t have one once I get around to it you are welcome to mine Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #748615 2nd Jan 2019 12:29am
pressbrake
Lovely Thumbs Up
Post #748637 2nd Jan 2019 10:19am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Clive I may be able to save you some leg work....I have one of your rear cross members for 110 tdi in the shed, never fitted it, as I ended up replacing the full chassis.
I could run a set of 3mm ply templates or trace onto cardboard from your original sections and send on if that would help.
Nidge
Post #748681 2nd Jan 2019 1:13pm
