Home > Puma (Tdci) > Designing a digitally controlled heater system, help needed.
Page 4 of 4 <1234
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
A few photos of the valve actuator.
Post #766599 2nd Apr 2019 10:44pm
B4Lamb
Post #766601 2nd Apr 2019 10:55pm
B4Lamb
Things have moved on and I found I needed to fit an 'end of travel' microswitch to detect when the valve was fully shut. I had hoped that I could just over step the motor into stall condition and then use that as the fully closed reference position, however the rack and pinion upgrade provides so much force that there was a danger of stripping the gear teeth. A roller type switch was added creating a bit more complexity, all stuff that make Mata's Solenoid valve solution much more attractive and less complicated.
However, I now have a fully working control system and one I can start to fine tune. It seems to hold set point temperature well but i'll instrument it to get more precise and accurate results. At the moment I have two temperature sensors one in the Matrix output air flow and the other in the cabin but not fully located in a dash spare switch bezel yet. The first software iteration is just using proportional feedback control on the Matrix air. I'll add an outer loop to provide corrections to get the cabin air correct to the set point value as the next version.
I'm using the original Bowden cable temperature control to adjust the user set point temperature. I eventually used a 40 mm long slider potentiometer with a 30 mm slide travel that works perfectly with the cable movement. The pot is located close to the heater valve in the engine bay where the Bowden cable ends up. I have fitted two tiny LEDs into a blank switch bezel on the dash to show when the heater valve is being opened or being closed. I found these handy so you can see at a glance what is going on.
I'm not controlling fan speed yet but I have included facilities to add 3 FET drivera on three outputs to control speed at a later date.
Next ill post some in car test results on a real trip although Winter is coming to an end so not an ideal test time now. "You are never to old to learn something new"
Post #767539 8th Apr 2019 7:36am
B4Lamb
Latest status of instrument cluster display mod to add an OLED for climate temperature info and other useful info.
More info coming soon on the control system and sensors. "You are never to old to learn something new"
Post #898747 17th Apr 2021 11:18am
bear100
Looking good Very Happy 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #898781 17th Apr 2021 5:45pm
Page 4 of 4 <1234
