Home > Technical > Catalytic Converter Removal
hank
I'm sure I read on this forum that removing the standard catalytic converter from a Puma in one piece is a swine of a job but I can't for the life of me locate the thread now.
I think I recollect reading some tips on how to get it out a bit more easily... Is anybody able to refresh my memory or point me in the direction of a thread?
Post #744930 10th Dec 2018 8:05am
I didn't have any trouble removing the front pipe from my 2007 2.4 when the flange broke off, but it is a very tight fit. You will need to remove the gearbox cross-member, and I have been told that the engine may need shifting to the n/s to make room, although mine didn't.
Post #744954 10th Dec 2018 12:11pm
Caterham
I didn't have to remove the engine but did need to remove the chassis and bulkhead.
only joking - above, tight but quite doable once the gearbox chassis thingy is removed. Thumbs Up
Post #744965 10th Dec 2018 2:17pm
hank
Nice. Thanks both, just the info I was after Thumbs Up
Post #744976 10th Dec 2018 3:01pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Laughing
Post #745000 10th Dec 2018 5:48pm
I forgot to add that if you're replacing it with a two-piece replacement pipe then you don't need to remove the cross-member if you cut the pipe that's coming off.
Post #745002 10th Dec 2018 5:56pm
hank
The original cat is going back on after some weight saving measures Whistle
Post #745096 11th Dec 2018 4:59am
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
Is it an easy job to remove the crossmember to get the down pipe off?
Post #889810 8th Mar 2021 11:14am
Dinnu
To remove the cross member it is just 4 bolts on each side. IIRC the nuts are welded on the crossmember, but I might be wrong there. The top bolts are quite ling as they go through the chassis. The lower ones are short as they go through a bracket welded at the bottom side of the chassis.
If crossmember has never been removed, it will fight you back and can be a bit difficult to budge and drop down. I prefer to put a small jack between the chassis rail and spread the chassis rails just enough for the crossmember to slide down. Care when taking this approach so as not to dent the chassis.. so use large wooden blocks to spread the load. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #889818 8th Mar 2021 11:36am
Willfindlay
Thanks for that, it looks easier to remove the anti roll bar, and perhaps more accessible by removing that. Do you think that’s an option.
Post #889897 8th Mar 2021 3:47pm
jst
it wont come out that way, you will need to take crossmember off.
for quick removal just park it on an industrial estate with poor lighting for a few nights, i am sure cat will be removed then.... prob along with rest of vehicle. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #889942 8th Mar 2021 6:19pm
hank
I simply could not get mine out Laughing removed the crossmember, unbolted an engine mount and tried to jack the engine out of the way a little but still couldn't manoeuvre the cat out. The fixing bracket has two fixing holes in it, I had to nip one off with an angle grinder to get it out > 110 XS Double Cab
Post #889948 8th Mar 2021 6:26pm
bear100
Yep it was a sod on mine must have took at least half an hour to get it out with a few grazed knuckles for good measure!
i was on the drive doing it though, it wasn't so bad just a lot of wiggling and head scratching! Shocked
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #889960 8th Mar 2021 6:54pm
