![]() | Home > Tdi > Emissions |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 ![]() ![]() ![]() |
![]() OJ |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Just watch your mix and don’t run it too thick, I’ve seen them melt pistons running too much cooking oil- injector starts dripping.
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
What was the emissions value?
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
Never got the figures, ,, i see you get less paperwork now and i had no advisories , and yeh cutting out the veg oil soon ,as the frost has arrived,
I always ask for the values so I can compare. I've found that properly warming the engine (20 mins @ 70mph) makes the biggest difference to emissions - usually a fast pass.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
My parents 1996 TDI (98k miles) fast passed the last few MOTs
![]() A good blast every once in a while does no harm and regular maintenance is a must ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Norton Member Since: 10 Sep 2018 Location: Buckinghamshire Posts: 28 ![]() ![]() ![]() |
Just goes to show - who cares about miles!!!
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
I had the same a few years ago - my tester said that if he had not had his machine calibrated the day before he would have said it was faulty. Lowest figure he had ever seen.
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5240 ![]() ![]() |
I always run my motors on good quality diesel and give them a good blast to get rid of the carbon crap out of the exhaust, Both my motors also run decat systems and ITG panel filters. EGRs have also been blanked ( defenders removed and binned)
Never had any problems with smoke tests, But as you say if they are looked after your laughing, I am not keen on tweaking diesels due to the smoke, I have seen some that are really smokey once been wound up. My 306 was a favourite to be remapped, I have not even touched it at all, still has a standard map on. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
