Home > Maintenance & Modifications > Replacement rear door handle
dickbowyer
United Kingdom 2011 Defender 90 Puma 2.2 SW Epsom Green
Rubber/plastic on my 2011 Defender rear handle has split and falling off (Part number FUB500060). Is there anyway to just replace plastic/rubber cover rather than large expense of replacing whole unit for £50 plus?
Post #743847 3rd Dec 2018 9:30pm
Grouse
Electric heat shrink
Post #743872 3rd Dec 2018 10:37pm
Litch
As above, heat shrink material.
Use the cap ended type.
To fit either remove the handle or make up a heat-shield to protect the paintwork (personally I would rather remove the handle to avoid any possibility of damage and also to ensure the material shinks evenly). ONE LIFE, GET IT!
Post #743975 4th Dec 2018 1:49pm
dickbowyer
Thanks for advice
Post #744726 8th Dec 2018 7:42pm
