Home > Wheels & Tyres > Mystery tubeless Wolf Wheels |
On a genuine Wolf HD wheel there are plenty of other markings, including the part number which starts by ANR plus 4 or 5 numbers. You can find all the details if you search for a few older « Wolf wheels » threads on here. See below.
To find out if yours are real or not, a first test is to weigh them. A genuine Wolf HD wheel comes in at about 16.2 kg on the scale. In one of those older threads there is discussion about some so-called genuine ones which weigh only about 12 kg. To use one of DJT.’s favorite expressions, those obviously are very fake. Eric https://www.defender2.net/forum/topic55943...preciation https://www.defender2.net/forum/topic31672...ls+genuine You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
10th Nov 2018 5:37pm |
Dreamweapon Member Since: 19 Dec 2016 Location: Hessische Odenwald Posts: 55 |
Thanks for your reply Eric, I had genuine HD wolf wheels on my old 300tdi and they had markings between the lugs, these are obviously aftermarket / pattern but the quality is quite good, I just don't know by who (Britpart, Bearmach, Paddocks?). They weigh in between 15.5 and 16 kg according to my bathroom scales and 7.5mm steel thickness at the hub according to my verniers.
I suspect these were manufactured pre-2006 before the EU norm on rim markings was introduced. These have no part numbers or any other information apart from the stamping inside the rim (brake side, thus the dust). |
10th Nov 2018 6:21pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Even the very early tube type WOLF rims had the part number stamped on them
12th Nov 2018 7:18am |
