Home > Maintenance & Modifications > uneven height after new suspension install |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 |
Hello,
I have recently changed the springs & shock absorbers on my defender 90 2013 along with the anti-roll bars and noticed the uneven height of the suspension(right side of the defender is higher than the left). Are there any adjustments that can alter that or adjusting the anti-roll bars. Thank you in advance, 2016 Defender 90 Adventure Edition |
1st Nov 2018 11:35am |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Defender springs are handed and colour coded (stripes down the coils) someone will be along to explain the codes I expect
1st Nov 2018 12:03pm |
spring colour coded
https://www.defender2.net/forum/topic41247.html (right side of the defender is higher than the left) your in luck around right way |
1st Nov 2018 12:06pm |
Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265 |
so that when the driver is sitting in the RH seat, it probs sits level. TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show! |
1st Nov 2018 3:40pm |
The setup i have are eibach springs and bilstein shocks, i will check with the installer and see how we can improve the stance. 2016 Defender 90 Adventure Edition |
2nd Nov 2018 5:47am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3672 |
Let us know how you get on.
2nd Nov 2018 6:08am |
2nd Nov 2018 6:59am |
Figured out the problem for the un even height as the rear right spring wasn't sitting properly on top and now is sitting as it is meant to be. All corner's are same height. 2016 Defender 90 Adventure Edition
4th Nov 2018 10:49am |
