Home > Maintenance & Modifications > what exhaust? need the whoosh!!
Page 2 of 4 <1234>
CarMan
I would say the noise between gear changes is the turbo waste gate venting to atmosphere rather than internally - at least it was on the Scooby Doo I used to hillclimb Mr. Green Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #736610 25th Oct 2018 7:46am
hank
I wonder whether a similar effect could be achieved at a fraction of the Alive cost with just a decat and centre silencer delete
Post #736612 25th Oct 2018 8:20am
pux146
My 90 is running a BAS remap to 180 with BAS inter-cooler & hoses, marrying that all up is a Griffin Exhaust! This gives it a very nice growl and the Woosh noise you are after between gear changes. I have tried to Video it but my phones crap! If you are near Wiltshire or oxford i am happy to take you out in it! 2007 2.4 90 fettled & remapped.
Post #736696 25th Oct 2018 3:12pm
Grouse
Yes, we have a Case 360 Excavator with a Cummins Turbo Diesel - the silencer was replaced with a 3” pipe, previously there was absolutely no whoosh at all. Now with the straight pipe you get an absolutely fantastic whoosh from the turbo when the throttle is released - Exactly the same scenario as if you were changing gears in a manual vehicle.
If you want the whoosh - just ditch the silencer
Post #736740 25th Oct 2018 7:34pm
bear100
Cheers guys,
Thanks Pux146 I may take you up on that offer!
New exhaust then intercooler, then a hybrid turbo maybe? Do they really make that much of a difference? Enough to justify the cost? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #736766 25th Oct 2018 9:04pm
pux146
I’ve got a lot more torque, fuel is better unless my right foot gets heavy! The exhaust sounds lovely but...on long journeys it can drone a bit! I have thought about upgrading the turbo, that’s currently on the back burner due to cost. If I could do anything to make it go better with the above then possibly change the diff ratios and the rubbish first gear. Is it worth the money....how longs a piece of sting! It’s all down to your wallet! 2007 2.4 90 fettled & remapped.
Post #736772 25th Oct 2018 9:13pm
Although a light tune is great bearing mind if you go much further you’ll likely reduce the lifespan of the engine and many other components. Perhaps not significantly but will do so in the long run.
This is why I’ve stayed with a stage 1, but everyone to their own decisions for what they see fit.
Also don’t forget the air box mod, that is free after all. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #736795 25th Oct 2018 10:12pm
pux146
Air box mod? Please tell, love a free mod! 2007 2.4 90 fettled & remapped.
Post #736796 25th Oct 2018 10:20pm
If you use the search function you should find the relevant info on here already.
You simply carefully cut out the top of the inlet section inside the air box, and remove the water separator too.
I've ran mine lie this with no issues at all for years already, there isn't that much to be achieved but you may get a little more intake growl and sharper throttle response.
Don't expect to be amazed but it does help reduce restriction and when tested by BAS the figures did show this also.
Although tested with RAI's and without I believe Pete also tested with and without the airbox mod done.
The results were a slight reduction in restriction, especially helpful if you have a Snorkel like mine does.
If you have a Snorkel or RAI the air box mod will mor ear less counteract the added restriction back to factory spec or very near.*
If you don't have a Snorkel or RAI then there is a little more to gain further, it's worthwhile either way in my opinion.
I have never had the slightest issue with mine.
Post #736800 25th Oct 2018 10:37pm
pux146
Thanks Steve, i shall look into that. Very Happy 2007 2.4 90 fettled & remapped.
Post #736828 26th Oct 2018 9:33am
hank
So this thread has been costly for me!
Allisport dummy cat, silencer delete and ITG filter ordered Rolling Eyes
Post #736856 26th Oct 2018 12:08pm
hank
Wonder what the sound would be like with a rear silencer delete Whistle
Is anybody aware of any information existing on hollowing out a factory defender TDCI catalytic converter?
Post #736857 26th Oct 2018 12:18pm
pux146
Does anyone know how to post a video on here, I videoed from inside the van and you can make out the woosh, I shall employ my other half tomorrow to film the landy going past 😂 2007 2.4 90 fettled & remapped.
Post #736890 26th Oct 2018 5:02pm
Hank - It has been done, but wasn't easy.
Pux146 - Paste the link into your post an it should magically appear. WeWillWin🇬🇧🇺🇸
Post #736894 26th Oct 2018 5:22pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
I have a spare air filter box, if you want to mod this one, off a ‘10 2.4. Removed it yesterday. PM.
Mod this one, them just swap them over. Thumbs Up
Post #736914 26th Oct 2018 6:39pm
Page 2 of 4 <1234>
