Home > Maintenance & Modifications > Your light bar set up?
Page 2 of 5 <12345>
Tommyharris
2013 Defender 90 Puma 2.2 HT Santorini Black
Found a 40” rigid e series combo reduced to 600 pound in a sale!!
Hovering above the buy button now, shes going to kill me!!
Those boosts that are tucked in the garage will have to go now.
“Its for safety babe honestly!! You need to see where your going on these winter nights”
Rolling with laughter
Post #735465 18th Oct 2018 8:17am
I have a full-width Chinesium bar tucked under the front of my Patriot rack, which does the job very well and was a fraction of the cost of Rigid etc. AS Roy5695 says above, after five years or so (which for me is getting on for 100k miles) it has a certain amount of condensation inside, it has a couple of failed LEDs, but it is still brighter than a bright thing and works well.
For the price I paid I could have bought a new one every year and still spent less than quarter the cost of the equivalent Rigid bar.
Post #735467 18th Oct 2018 8:29am
leeds
Lazer T 16 and two Lightforce Striker 170 fitted onto a custom made twin light bar. Not road legal as the T16 does not carry an approval mark. The Led bar and the 2 strikers are on two separate switches so have choice what to have on. Not wired through main beam switch which is a legal requirement.
It is useful if going on long trips to have optional driving lights on a complete separate light circuit. Not technically legal for road use but is a useful backup for when main headlight circuits fail.
A big Vision X LED bar mounted on some special mounts so that the light bar is still below main roof height. Useful if height restrictions are important. These big LED bars are not type approved and so not road legal. They give out massive amounts of lights which can cause issues with reflections and also when switched off you drive blind for a few seconds whilst drivers eyes adjust to vastly different light levels. I prefer smaller LED lights independently switched so can have choice of light output.
Type approved LED headlights with approved spot lights and LED bar. The LED bar and spot lights can be switched on independent of the main headlights which in this mode are not road legal. They can also be switched through the main beam switch so are then road legal.
Road legal to use these headlights and the LED light bar or the LED headlights and the LED spot lights. Not road legal to use the LED headlights and the LED bar and the LED spotlights as exceed the PBRN limit for legal road use.
Brendan
Post #735517 18th Oct 2018 12:12pm
Tommyharris
Brendan,
Thank you for the advice mate. You've got some very very nice kit on your website!
I wouldn't be able to get the overtime in quick enough so if you ever offer finance I'll have one of everything!
Roof tent, that fancy looking bbq, rear wheel carrier etc to start
Regards tom
Post #735627 18th Oct 2018 9:36pm
Tommyharris
Afternoon chaps,
Just an update on the old lightbar situation.
Decided to go down the cheaper route first to see what the score is, if i like what lightbars do then when this one packs up ill chase a branded one a bit later.
So i picked up a 40” aurora bar from devon 4x4 whilst looking at a tent. It was £360 in the end.
I haven’t wired it up yet so ill let you know once im up and running.
Ive tried going down the non roof drilling route by passing the wire through the rear washer jet (never used it) bit of an eyesore at the moment but ill make a cover that bolts to the rack.
Post #740692 15th Nov 2018 4:58pm
Grenadier
Roy5695 wrote:
I’ll mix it up with two 20” bars. Only cheap chinese stuff but work wonderfully on the Cornish country lanes. There’s never more than 100 before a corner anyway. They’re about 4 years old. Condensation is an issue and also a few dead LEDs will be replaced with a pair of rigid units in the new year.
Cracking DCPU Roy. Bow down Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #740704 15th Nov 2018 6:07pm
Sulisuli
Grenadier I have seen Roys DCPU and it’s a stunning example with some great mods Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #740708 15th Nov 2018 6:31pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Does the DCPU have dual snow cowls?
Post #740828 16th Nov 2018 4:34pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I have just fitted a Lazer R28 to the roof of my 90 and at any speed above 50mph it whistles extremely loud.
Has any one else using this bar encountered this problem?
I see Lazer sells neoprene covers which say they combat wind noise, and whilst they look smart it would be a pain to take on and off every time you want to use the light Sad
Post #745169 11th Dec 2018 3:13pm
Tombte
Spain 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Installed a 40' SR from Rigid. Awesome in performance and very slim. Fitted on a ROC-ARD lightbar.
Post #745175 11th Dec 2018 4:02pm
leeds
There is not one simple guaranteed answer to your problem. It is a case of trying different things.
The wind noise is caused by the wind going over the back of the cooling fins at the back of light bar.
There are some very simple tricks to try some of them are suck it and see.
Try angling the LED light bar down slightly. OK limits reach of light pattern a bit.
Move the light bar back a few inches.
Some people have had success using double side tape to stick on the household door insulator plastic strip type.
Another alternative is small bits of tape foam insulation or pieces of plastic in between the cooling fins leaving a decent space between them
Failing all else the Americans do a shaped clear plastic tube which clips around the light bar Look here
As I say a suck it and see type operation
On our green 110 with a long Vision X light bar no wind noise but it is mounted low down.
Grey 90 with 20"? Vision X had to move it back slightly to cure noise
HTH
Brendan
Post #745197 11th Dec 2018 6:08pm
2010Blackdefender90
Think it’s the angle you have the bar, as said, trying angling down or moving back, suspect wind resistance bouncing back up off the windscreen might be a cause too, as well as wind channelling down over the bar...
Have had th4 same issues, moved rack back from edge of screen so the air woent over the lens, and also angled down slightly... stopped it.
Post #745286 12th Dec 2018 11:07am
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Damn should have read this thread before buying a Lazer Triple R T24.
Anyway, my plan is to installed it on a FD rack or Patriot rack and wiring via snorkel route.
One question, what sort of mount needed to mount on the rack? Is it the 3x centre mount or the side mount? Or neither?
Post #748147 30th Dec 2018 10:51pm
2010Blackdefender90
https://jeepey.com/product/led-light-bar-r...s-rrac124/
I’m using these for mounting on my cargobear rack, but they should work on FR rack for what you need Thumbs Up
Post #748161 31st Dec 2018 12:08am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
It does, one for the heater intake and one for the engine intake 😎
Thanks Grenadier and Thank you Simon. [/quote] 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #748261 31st Dec 2018 3:44pm
Page 2 of 5 <12345>
