Home > Puma (Tdci) > Intemittent starting problem |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
sounds like fuel starvation doesnt it. Checked filter and water trap etc ?
26th Apr 2011 8:11am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
It's the imobilizer, known fault, lock and unlock the truck twice,wait a few seconds then it will fire as normal 2.4 90 XS
26th Apr 2011 8:45am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
I have the same from time to time. Still do not know how to fix it. Puma 110" SW
26th Apr 2011 9:41am |
Portafilter Member Since: 08 Aug 2010 Location: Melbourne Posts: 27 |
I had the same problem along with loss of power for a couple of seconds between 2nd and 3 rd gear.
Fixed it by replacing the fuel pressure reg and the sensor in the fuel pump. As a byproduct it transformed the truck. More power, smoother running and better throttle response. Also way better mpg. Justin |
26th Apr 2011 10:10am |
