![]() | Home > Puma (Tdci) > Pipercross Performance Air Filter |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
Hello,
Does anyone know that kind of air filter? http://www.paddockspares.com/pp/DEFENDER/E..._TDCI.html I'd like to protect my engine from dust. Are they better than genuine ones. Thanks ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
I would imagine so although personally i would choose ITG: http://www.td5alive.com/acatalog/Air_Filters.html
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
We supply Pipercross filters (made to our own spec, and with our branding), and ITG.
Both are excellent, but the Pipercross normally comes in two-ply form (two layers of foam), which I did not find satisfactory, so I had mine made with a very fine top, third layer to arrest more dust particles. ITG filters are thicker, and so have a greater dust retention capacity than the Pipercross, and several times that of a K&N type filter. ![]() However, All 'performance' air filters are oiled. This oil is there to capture the dirt, and hold it in place, preventing it from pulling through the foam or gauze. The problem I see in your case is that in very dusty conditions, your oiled air filter is going to attract more of the airbourne dust, which will stick to the filter,and blind it quickly. A paper filter on the other hand, is completely dry, and so any course particles will fall to the base of the air box, especially after engine shut down. Some paper element filters have a foam pre-filter too, which further increased filter life, by trapping the dust before it has chance to make it to the pleated paper sections. As a rule, I will only recommend performance filters, if the customer will be using the car in fairly clean conditions. For use in dusty conditons, I always recommend the use of an original spec paper element filter, which when clean, should still flow more than enough air for even a well tuned engine. If the use in dirty conditions is only occasional, then it is a good option to use a performance filter, until the next time you expose it to high dust levels, when you refit the paper filter. Hope this makes sense?! ![]() Regards, Gary. |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 141 ![]() ![]() |
Hi,
Noticed Britpart Have a Peak Performance Air filter - anybody tried one ? Cheers |
