Home > Puma (Tdci) > ScanGauge II - is this a good deal? |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 |
Arrived, fitted (amazingly thanks to you guys without a hitch) and now working, still on first tank so not calibrated (giving frighteningly low instant MPG readings - so hope it is wrong_. Anyhow, quick question, says i have to select diesel type a or b, anyone know what normal UK stuff is (ie,BP / Tesco et al)
28th Apr 2011 9:30am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Taken from the Scangauge II manual....
============================= DIESELa and DIESELb do not refer to different types of diesel fuel. They only affect the way fuel consumption is computed and are selected based on the way the vehicle computer reports its sensor information. Most diesel vehicles use the DIESELa setting. To determine which your diesel vehicle uses, do the following: With ENGINE SIZE set, DIESELa chosen for fuel, the engine warmed up to operating temperature and idling in neutral or park, select GAUGE and make one of the gauges show RPM and another show GPH. Note the GPH value. Next, use the throttle to raise the engine RPM to about 1500 RPM. If the GPH reading increased, you have a DIESELa vehicle. If the GPH dropped or stayed the same, you have a DIESELb vehicle and should change the Fuel Type to DIESELb. ============================== ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
28th Apr 2011 10:01am |
Got you - then i guess everyone with a Puma and using a scanguage must know the answer
28th Apr 2011 10:46am |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
I thought same, but then perhaps we're both forgetting that we are talking about Landrovers As an aside, I just rang the company to ask about whether this would work on a Td5, (I see no reason why not as I have the OBI- WAN KENOBI socket). Their tech support chap is on hols until next week. Anybody see any reason why this shouldn't work on a 2005 Td5 ? - I seem to think that in the past I read that Scanguages didn't like Td5's.... Jon - 110 td5 [sold]. Currently Defenderless. |
28th Apr 2011 10:53am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Its something to make you more of a 'hypochondriac' and another thing to distract you from the road ahead...
I love mine Joking !! I once helped build a Warrior off road racer, we had a problem with keeping the running temperature down, the guy who makes the spaceframes was called about our concerns.. He said ''cover the temperature gauge up with tape'' |
28th Apr 2011 11:26am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Are these good for diagnostics though? I know it says you can read and reset codes but am I correct in thinking that you need something else to translate the code so you know what the fault is? John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
28th Apr 2011 11:32am |
The scangauge only shows tested DTC's which illuminate the MIL light. The ford dtc fault code list is on here if you do a search, it was uploaded by dgardel. |
28th Apr 2011 12:06pm |
Thanks for that - I'll search for it.
I'd like a decent diagnostic tool for the Puma when it arrives - if it could do a TD5 as well that would be a bonus. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
28th Apr 2011 1:31pm |
Have had a response back from some other chap at the OBD UK crowd. They tell me the Scanguage II won't work on a Td5. They didn't elaborate as to why.
Just dug back through an old post of mine and our diagnostics guru (aka Lorryman) had already told me this on a post a few months back..... I had a niggling feeling that somebody had told me already... Must pay more attention in class Jon - 110 td5 [sold]. Currently Defenderless. |
29th Apr 2011 6:35am |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Hi !
This maybe a stupid question ... ... What is the diference between the ScanGauge and NanoCom ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
29th Apr 2011 1:20pm |
The scanguage is basically a monitoring tool with the ability to clear tested DTC's. It allows you to monitor rpm/engine load/MPL/LPH/coolant temp (cylinder head)/MAP/TPS/MPH and a lot more all in a small package that is easy to mount permanently in the vehicle. The Nanocom does give you readings on some system info but it is more of a diagnostic machine dealing with Puma engine/Instrument cluster/10AS Alarm and Wabco ABS. I also wouldn't leave the nanocom mounted in the vehicle as it could be used to aid in the theft of the vehicle Plus it's size makes mounting quite difficult for a clean install IMHO. HTH Brian. |
29th Apr 2011 8:31pm |
Have a look at the Nanocom Evolution available from Blackbox solutions as you can have the Puma and TD5 version in one unit. |
29th Apr 2011 8:33pm |
Thank you Lorryman!
Just one last question ... what are tested DTC's ? sorry for the topic hijack ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
29th Apr 2011 10:42pm |
Taken from another post I did
30th Apr 2011 10:03am |
