![]() | Home > Tdi > 300tdi mpg post rebuild |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
I think the metal head gasket are a much better job, if you do change it. I’m sure you’ll see an improvement with them as I’m sure the atomisation isn’t great anymore
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
What did I write about no leaks for? The transfer box is weeping well above the inspection plate....
