horus1970
starting valve clearances from fully backed off adjusters? | |
ive just installed a new rocker shaft and to make installing it easier i backed all the adjusters right off, and now i need to set them again,
do i just screw all of them in until the balls on bottom of adjusters are seated in pushrod cups? then start the rule of nine procedure? was just thinking some will have to partialy push down a valve spring,,,
am i missing any part of the procedure out? cheers
28th Sep 2018 8:53pm |
