![]() | Home > V8 > 50th anniversary exhaust route |
NAS90 Member Since: 26 Sep 2018 Location: Norfolk Posts: 45 ![]() ![]() |
Standard 50ths are all Automatics, the 50th didn't come in manual.
If it helps the 1994 & 1995 NAS Defenders are V8 manual, they have a Y Pipe that comes from the manifolds, run underneath the gearbox crossmember and then come together under the transfer case into a flange that bolts to the rear section silencer (they are LHD though). Link to a photo I found shows a 1995 NAS https://www.schmitt.com/wp-content/uploads...-90-51.jpg Is there such a thing as too many Defenders?.... NAS90 Soft Top, 50th Anniversary, Spectre 110 Puma, Ex Italian Police 90 with JE V8 Auto |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
It goes under the cross member.
Must fit cross member first. Check out video below as it shows the area you require ![]() |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Thanks for the prompt replies fellas. In the words of the immortal bard, bow locks. won't fit a 110 then
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 175 ![]() |
Not sure what system you have at the moment, or if this is any help, but you can make up something that fits from off the shelf bits...
IIRC its: 3.9 cast manifolds RRC Y Pipe 110 TD5 / Puma centre / rear section (can be sourced as take offs cheap on ebay) You need to change one of the centre hangars and possibly fabricate a rear hangar but it all bolts up together. This is what I've got on mine ![]() |
I don't understand your problem....
I have a 110 with v8 and auto. Disco1 or RR Classic V8 cross member with easy modification. I have a 300tdi intermediate pipe and tailpipe on mine |
What is the easy modification to the Xmember, please?
From what I remember you have to use the Disco / RRC X Member and weld a bit on the bottom to extend the mounts - the defender one is straight, the disco ones are like this:
\____/ the Y pipe fits up in the nooks of the x member |
Help?
It is a bit perplexing because at least 2 X members for the discovery have the same part No as the equivalent 110 item.
Have a read through this:
https://forums.lr4x4.com/topic/82281-v8-exhaust/ ![]() |
A thought occurs, does anybody know the part no for the X member on a 50th anniversary, please?
Found it, eventually, in the NAS 110/90 parts list. NTC9241
Good luck on that one...
I got a steel fabricator to weld some plate on each end to mak it square, bolted it in on top bolts, then drilled through holes in lower brackets on chassis and into the cross member, bolts in with plenty of copper slip . All done and on with fitting exhaust ![]() |
Available from Land Rover, 262 +vat.
Presumably since the same xmember was used on both NAS models 90/110 and the 50th anniversary then at least some of the chassis manufacturers will make them as well. |
